[fusion-dev] Replacing the Redline widget
Arthur Liu arthur.liu at autodesk.com
Mon Jun 20 22:59:53 EDT 2011
Hi Jackie,
We would really appreciate if you could replace the redline widget with the enhanced one. There's no opposition from this side.
The only concern is about time. It would be great if this enhancement could be accomplished before end of July so that we could allocate enough time to test it.
Thanks again.
Regards,
Arthur
-----Original Message-----
From: fusion-dev-bounces at lists.osgeo.org [mailto:fusion-dev-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Monday, June 20, 2011 11:35 AM
To: fusion-dev at lists.osgeo.org
Subject: [fusion-dev] Replacing the Redline widget
Hi All,
This question is mainly directed at the Autodesk developers.
The current redline widget is woefully inadequate for redlining. We have internally replaced this widget with one based on the original redlining sample (written by you guys) for the basic AJAX viewer, which is much more functional.
The relevant ticket is here: http://trac.osgeo.org/fusion/ticket/461
Is there any opposition to replace the current redline widget with the one proposed in this ticket?
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Replacing-the-Redline-widget-tp6494549p6494549.html
Sent from the Fusion Developers mailing list archive at Nabble.com.
fusion-dev mailing list
http://lists.osgeo.org/mailman/listinfo/fusion-dev
More information about the fusion-dev mailing list
