[fusion-dev] Re: Adding WMS in Application Definition
Jackie Ng jumpinjackie at gmail.com
Tue Jun 28 07:24:36 EDT 2011
Each <Map> in the <MapGroup> corresponds to a OpenLayers.Layer being created
and added to the OpenLayers map object when Fusion is initialized.
Do you see an OpenLayers.Layer.WMS in your OpenLayers map if you take a peek
through firebug?
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Adding-WMS-in-Application-Definition-tp6514397p6524477.html
Sent from the Fusion Developers mailing list archive at Nabble.com.
More information about the fusion-dev mailing list
