[fusion-dev] Fusion error.
Michael Adair madair at dmsolutions.ca
Tue Nov 22 10:45:07 EST 2011
I'm guessing your are trying to use MapServer 6.0 which isn't supported
by Fusion yet.    This is supposed to be addressed in the coming months.
Mike
On 20/11/2011 2:32 PM, 05bca054 wrote:
> Hello there,
>    I get this error when run the sample fusion example in ms4w mapserver.
> Fusion Error: WARNING:
> Exception occurred in AJAX callback.
> Message: missing ; before statement
> Location : http://localhost:9999/fusion/MapServer/MapServer.js (226)
> Response : Fatal error: Uncaught exception 'MapScriptException' with message
> 'Property 'imagetype' does not exist in this object.'
>   in C:\ms4w\apps\fusion\MapServer\php\LoadMap.php:129 Stack trace: #0
> C:\ms4w\apps\fusion\MapServer\php\LoadMap.php(129):
> mapObj->__get('imagetype') #1 {main} thrown in
> C:\ms4w\apps\fusion\MapServer\php\LoadMap.php on line 129
> index.html (line 101)
> Location: http://localhost:9999/fusion/MapServer/MapServer.js (226)
> Response: Fatal error: Uncaught exception 'MapScriptException' with message
> 'Property 'imagetype' does not exist in this object.' in
>               Thanks for your times and consideration...
> Regards,
>     Naitik joshi(ewebkraft.)
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fusion-error-tp7014336p7014336.html
> Sent from the Fusion Developers mailing list archive at Nabble.com.
> fusion-dev mailing list
> fusion-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-dev
More information about the fusion-dev mailing list
