[fusion-dev] RE: Replacing the Redline widget
Jackie Ng
jumpinjackie at gmail.com
Thu Sep 1 04:39:59 EDT 2011
Hi Mars,
As of r2427, everything has been done for this widget.
Cheers,
- Jackie
On 1 September 2011 12:55, Mars Wu <mars.wu at autodesk.com> wrote:
> Hi Jackie,
> I saw your submission for replacing the widget. Just to confirm: has
> everything been done for the new widget?
> Thanks,
> Mars
> -----Original Message-----
> From: fusion-dev-bounces at lists.osgeo.org [mailto:
> fusion-dev-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> Sent: Tuesday, June 21, 2011 5:19 PM
> To: fusion-dev at lists.osgeo.org
> Subject: [fusion-dev] RE: Replacing the Redline widget
> Sure no problem. It's mostly done, just lacks the required localization.
> - Jackie
> http://osgeo-org.1803224.n2.nabble.com/Replacing-the-Redline-widget-tp6494549p6499201.html
> Sent from the Fusion Developers mailing list archive at Nabble.com.
> fusion-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/fusion-dev
Blog: http://themapguyde.blogspot.com
LinkedIn: http://www.linkedin.com/in/jackieng
Twitter: http://twitter.com/jumpinjackie
URL: http://lists.osgeo.org/pipermail/fusion-dev/attachments/20110901/6eaa2058/attachment.html
More information about the fusion-dev
