[fusion-trac] #53: single file build
Fusion trac_fusion at osgeo.org
Fri Apr 25 14:39:13 EDT 2008
   Reporter:  madair  |       Owner:  madair
       Type:  defect  |      Status:  new
   Priority:  P1      |   Milestone:
  Component:  Core    |     Version:  1.0.4
   Severity:  Major   |    Keywords:
External_id:          |       State:  New
    Browser:  All     |          Os:  All
 add a build target to create a 'compiled' app that would do the following:
 * analyse the application definition and create a single file build that
 includes only the widgets referenced by the application definition
 * pre-process the application definition into a json object and include it
 in the single file build
 * include config.json in the single file build
 The result would be a template that loads a single javascript file that
 includes everything required to get started.
 Implement the YUI compressor in build.xml
Ticket URL: <http://trac.osgeo.org/fusion/ticket/53>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
