[fusion-trac] #113: Can't zoom out beyond initial map view
Fusion trac_fusion at osgeo.org
Mon Aug 25 14:21:12 EDT 2008
   Reporter:  andrewd   |       Owner:  madair
       Type:  defect    |      Status:  new
   Priority:  P2        |   Milestone:  1.1
  Component:  Core      |     Version:  SVN
   Severity:  Critical  |    Keywords:
External_id:            |       State:  New
    Browser:  All       |          Os:  All
 This happens in all of my Fusion layouts...I have a map with an 'initial
 view' area set. My layers are set to be viewed to a max of infinite. I
 have no base layers or scale ranges.
 With that set up, when I load my Fusion map in the browser, the zoom
 slider is all the way at the bottom, so I can't pull it down to zoom out
 any more. I also can't seem to type in a larger scale in the status bar (I
 can type it, but it just resets back to where it was - unless I want to
 zoom in)...also, pressing the 'zoom out' tool does nothing for me either.
 Since it affects more than just the navigator widget, it must be something
 bigger - something in MapGuide.js maybe?
Ticket URL: <http://trac.osgeo.org/fusion/ticket/113>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
