[fusion-trac] #193: SaveMap widget is broken
Fusion trac_fusion at osgeo.org
Wed Dec 17 12:12:10 EST 2008
 Reporter:  chrisclaydon        |         Owner:  madair
     Type:  defect              |        Status:  new
 Priority:  P1                  |     Milestone:  2.0
Component:  Widgets             |       Version:  SVN
 Severity:  Major               |    Resolution:
 Keywords:                      |   External_id:  1177426
    State:  Analysis Requested  |       Browser:  All
       Os:  All                 |
Comment (by chrisclaydon):
 Object.inheritFrom is called only if the format is set to DWF. This
 appears to make the object initialize itself twice, and it fails the
 second time through.
 If the call to Object.inheritFrom is removed, the widget initialization
 succeeds, but some of the paths in the widget are incorrect, since the
 MapGuide folder has been moved.
 Also, in browsers other than IE, the widget loads the new image into a
 hidden frame, which doesn't allow the user to view or save it.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/193#comment:2>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
