[fusion-trac] #73: need to initialize units when viewOptions widget
is not used
Fusion
trac_fusion at osgeo.org
Wed Jun 4 09:53:40 EDT 2008
#73: need to initialize units when viewOptions widget is not used
Reporter: madair | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: 1.0.7
Component: Widgets | Version: 1.0.6
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
the setting units for various widgets currently happens in the ViewOptions
widget. If that widget is not included in an AppDef, then widgets
depending on the viewOptions widget will not be initialized and units
appear as "unk". Solution is to move the init method into the Map object
and called on MAP_LOADED event.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/73>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
