[fusion-trac] #76: Checking layers in the legend not working correctly
Fusion
trac_fusion at osgeo.org
Tue Jun 10 09:11:05 EDT 2008
Reporter: schneiderei | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: 1.1
Component: MapServer | Version: 1.0.6
Severity: Critical | Keywords: MapServer, Legend
External_id: | State: New
Browser: All | Os: All
After starting a Fusion map application, the visibility of the map layers
and the status in the legend are in synch, that is, all map layers that
are checked in the legend and only these are visible in the map. However,
after unchecking a map layer, it remains visible in the map, if checked it
again, it's gone from the map only to reappear when unchecking it.
I am using MapServer 5.something (sorry, can't tell which version
exactly).
It may be in the functions show() and hide() of
Fusion.Maps.MapServer.Layer and Fusion.Maps.MapServer.Group. In the four
functions, redrawing of the map is triggered through showLayer(..),
hideLayer(..) and showGroup(..), hideGroup(..), respectively. Then,
statements that change the value of the visibility flag follow. I suspect
that the latter statement should occur before (!) the calls showLayer(..),
etc. I tested it, and it fixed the problem.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/76>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
