[fusion-trac] #82: Reference to non-existing this.oMap in Fusion.Maps.MapServer.showGroup(..) and ...hideGroup(..)
Fusion trac_fusion at osgeo.org
Fri Jun 20 10:02:50 EDT 2008
   Reporter:  schneiderei  |       Owner:  madair
       Type:  defect       |      Status:  new
   Priority:  P2           |   Milestone:  1.1
  Component:  MapServer    |     Version:  1.0.6
   Severity:  Major        |    Keywords:  MapServer, Legend, Groups, Layers
External_id:               |       State:  New
    Browser:  All          |          Os:  All
 Writing a Fusion application based on MapServer 5.0.2, I experienced some
 incorrect behaviour in the legend. Often, if I click a group, the map is
 not redrawn. With other groups, redrawing was triggered as expected. I was
 not able to identify a logic behind this that could help reproducing the
 error. However, I found something that I think is a bug in
 MapServer/MapServer.js. Fixing this issue also fixed the incorrect
 In the methods Fusion.Maps.MapServer.showGroup(..) and
 Fusion.Maps.MapServer.hideGroup(..), there are calls to this.oMap. I am
 not sure, but I think that the MapServer object does not have such a
 field. However, another object in the two methods, namely group, does have
 a field oMap. Thus, I suspect that there is a bug stemming from a typo or
 from some unfinished copy/paste.
 I suggest changing the lines as follows:
           this.oMap.showLayer(group.layers[i].layerName);
 should become
           this.showLayer(group.layers[i].layerName);
 and
           this.oMap.hideLayer(group.layers[i].layerName);
 should become
           this.hideLayer(group.layers[i].layerName);
 It works in my application. Perhaps someone knowledgable should have a
 look at this and determine if this is indeed something that needs to be
 fixed.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/82>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
