[fusion-trac] #2: [Fusion] Cursor Position widget appears to be reporting incorrect location
Fusion trac_fusion at osgeo.org
Tue May 6 10:46:07 EDT 2008
 Reporter:  jfournier  |         Owner:  madair
     Type:  defect     |        Status:  closed
 Priority:  P1         |     Milestone:  1.1
Component:  Widgets    |       Version:  1.0.2
 Severity:  Major      |    Resolution:  fixed
 Keywords:             |   External_id:
    State:  New        |       Browser:  All
       Os:  All        |
Changes (by madair):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 (In [1388]) closes #2: add methods to get and set the MeterPerUnit value
 as returned by LoadMap (rather than using hard-coded values for meters per
 degree)
Ticket URL: <http://trac.osgeo.org/fusion/ticket/2#comment:3>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
