[fusion-trac] #2: [Fusion] Cursor Position widget appears to be reporting incorrect location
Fusion trac_fusion at osgeo.org
Fri May 9 11:46:30 EDT 2008
 Reporter:  jfournier  |         Owner:  madair
     Type:  defect     |        Status:  reopened
 Priority:  P1         |     Milestone:  1.0.5
Component:  Widgets    |       Version:  1.0.2
 Severity:  Major      |    Resolution:
 Keywords:             |   External_id:
    State:  New        |       Browser:  All
       Os:  All        |
Comment (by madair):
 The warning is being issued correctly I believe (it happens when the
 OverviewMap tries to set the metersPerUnit value.  I can suppress the
 error being issued if the value is the same as teh value already set.
 Part of the issue is that some of the templates define an error callback
 that issues an alert.  Those should probably be changed so that only real
 errors (not warnings) are alerted.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/2#comment:7>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
