[fusion-trac] #64: Mapguide error:The value cannot be less than or equal to zero.
Fusion trac_fusion at osgeo.org
Tue May 13 23:29:54 EDT 2008
   Reporter:  zspitzer  |       Owner:  madair
       Type:  defect    |      Status:  new
   Priority:  P2        |   Milestone:
  Component:  MapGuide  |     Version:
   Severity:  Major     |    Keywords:
External_id:            |       State:  New
    Browser:  All       |          Os:  All
 Using 1.0.6 with a tiled map, i am seeing the following error in the
 mapguide server logs viewing the tiled Sheboygan map sample and the slate
 template with both FF2 and IE7.
 There is no obvious problem i can see as a result of this error. It occurs
 using the zoom rectangle tool to zoom in.
 mapguide access.log
 <2008-05-14T13:20:20>                   Anonymous
 QueryFeatures.1.0.0:7(Session:1bc12a1a-0000-1000-8001-
 00188b8b4aed_en_7F0000010AFC0AFB0AFA//Sheboygan482a59a37a3ac.Map,MgStringCollection,MgGeometry,4,,1,3)
 Failure
 apache access.log
 10.3.136.158 - - [14/May/2008:13:20:20 +1000] "GET
 /mapguide/mapagent/mapagent.fcgi?&version=1.0.0&locale=en&operation=QUERYMAPFEATURES&session=
 00188b8b4aed_en_7F0000010AFC0AFB0AFA&mapname=Sheboygan482a59a37a3ac&geometry=POLYGON((-87.70418013242478%2043.76565229696846%2C%
 20-87.70418013242478%2043.76561679407961%2C%20-
 87.70414462953593%2043.76561679407961%2C%20-
 87.70414462953593%2043.76565229696846%2C%20-
 87.70418013242478%2043.76565229696846))&maxFeatures=1&persist=0&selectionVariant=INTERSECTS&layerNames=
 HTTP/1.1" 559 522
 mapguide error.log
  Error: Invalid argument(s):
  StackTrace:
   - MgRenderingServiceHandler.ProcessOperation line 83 file
 d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.13\mgdev\server\src\services\rendering\RenderingServiceHandler.cpp
   - MgOpQueryFeatures.Execute line 125 file
 d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.13\mgdev\server\src\services\rendering\OpQueryFeatures.cpp
   - MgServerRenderingService.QueryFeatures line 652 file
 d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.13\mgdev\server\src\services\rendering\ServerRenderingService.cpp
   - MgServerRenderingService.RenderForSelection line 1041 file
Ticket URL: <http://trac.osgeo.org/fusion/ticket/64>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
