[fusion-trac] #65: mgmapresourceid URL override patch
Fusion trac_fusion at osgeo.org
Wed May 14 18:36:55 EDT 2008
   Reporter:  amorsell     |       Owner:  madair
       Type:  enhancement  |      Status:  new
   Priority:  P3           |   Milestone:  1.1
  Component:  MapGuide     |     Version:  1.0.6
   Severity:  Trivial      |    Keywords:
External_id:               |       State:  New
    Browser:  All          |          Os:  All
 This patch is to add functionality to pass a mapguide map resource ID via
 a URL parameter to Fusion and have it open that map in a given Fusion
 applicationDefinition.
 Edit the Fusion.Lib.ApplicationDefinition.Map class in
 applicationDefinition.js from (around line 534):
 this.resourceId = this.extension.ResourceId ? this.extension.ResourceId[0]
 if ( !Fusion.Maps[this.type] ) {
 to:
 var paramMgMapResourceId = Fusion.getQueryParam('mgmapresourceid');
 if (paramMgMapResourceId.length>0) {
      this.resourceId = paramMgMapResourceId;
 Once this patch is in place, if you pass a map resource ID at the URL,
 Fusion will pick that up and use it instead of the one in the appDef file.
 In my case, I actually removed the contents of my ResourceId tag in the
 MapSet definition.  This can be tested by making a copy of the Sheboygan
 map and calling it Sheboygan_2 (make some changes to it so you can tell
 the difference between it and the regular Sheboygan map).  Then, enter the
 following URL address into your browser:
 http://YOURSERVER:8008/mapguide/fusion/templates/mapguide/slate/index.html?mgmapresourceid=Library://Samples/Sheboygan/Maps/Sheboygan_2.MapDefinition
Ticket URL: <http://trac.osgeo.org/fusion/ticket/65>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
