[fusion-trac] #71: SelectionPanel: Capability to customize display results
Fusion trac_fusion at osgeo.org
Wed May 28 16:25:38 EDT 2008
 Reporter:  aboudreault  |         Owner:  aboudreault
     Type:  enhancement  |        Status:  new
 Priority:  P2           |     Milestone:  1.1
Component:  Widgets      |       Version:  1.0.6
 Severity:  Major        |    Resolution:
 Keywords:               |   External_id:
    State:  New          |       Browser:  All
       Os:  All          |
Comment (by pagameba):
 Alan, I think the existing API can be used and there doesn't need to be a
 new widget.  At the end of the [wiki:MapGuideTutorial] is a description of
 how to use the selection API (not sure if it is up to date) - this should
 be rewritten as a cookbook recipe and users wanting to customize the
 selection output could start there.  The new recipe should include a
 complete functional example that can be added to a Fusion application
 outside of the widget structure.
 What do you think?
Ticket URL: <http://trac.osgeo.org/fusion/ticket/71#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
