[fusion-trac] #71: SelectionPanel: Capability to customize display results
Fusion trac_fusion at osgeo.org
Wed May 28 19:54:13 EDT 2008
 Reporter:  aboudreault  |         Owner:  aboudreault
     Type:  enhancement  |        Status:  new
 Priority:  P2           |     Milestone:  1.1
Component:  Widgets      |       Version:  1.0.6
 Severity:  Major        |    Resolution:
 Keywords:               |   External_id:
    State:  New          |       Browser:  All
       Os:  All          |
Comment (by aboudreault):
 I agree, the existing API would do the job. I didn't see this part of the
 code. So, i think the SelectionPanel widget should use it at best it can.
 It needs to allow us to set the user function that will process the
 results and support results in batches (good to hear that the api already
 support it). If no default function is provided by the user, the widget
 will just uses the current display (with combobox, etc.). Also, this
 selection documentation would have it own part somewhere, and not only in
 the mapguide specific section.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/71#comment:4>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
