[fusion-trac] #143: Incorrect scale displayed for maps using units other than meters
Fusion trac_fusion at osgeo.org
Wed Nov 5 14:21:54 EST 2008
 Reporter:  chrisclaydon        |         Owner:  madair
     Type:  defect              |        Status:  assigned
 Priority:  P1                  |     Milestone:  2.0
Component:  Widgets             |       Version:  SVN
 Severity:  Major               |    Resolution:
 Keywords:                      |   External_id:  1085634
    State:  Analysis Requested  |       Browser:  All
       Os:  All                 |
Changes (by madair):
  * status:  new => assigned
Comment:
 can you clarify what the issue is here please:
 - is it that the scale value displayed in the status bar is incorrect?
 - or is it that a scale value element in an InitialView in AppDef doesn't
 get interpreted correctly?
 I'm testing with the Sheboygan sample which is a map in degrees
Ticket URL: <http://trac.osgeo.org/fusion/ticket/143#comment:2>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
