[fusion-trac] #153: Print widget causes error
Fusion
trac_fusion at osgeo.org
Thu Nov 6 13:32:55 EST 2008
Reporter: chrisclaydon | Owner: pagameba
Type: defect | Status: closed
Priority: P1 | Milestone: 2.0
Component: Widgets | Version: SVN
Severity: Major | Resolution: fixed
Keywords: | External_id: 1152462
State: Analysing | Browser: All
Os: All |
Changes (by pagameba):
* status: assigned => closed
* resolution: => fixed
Comment:
(In [1643]) Fixes #153. Jx no longer provides the getObj interface, it
was removed as unnecessary because getElementById is now supported on sub-
elements by MooTools. The Print dialog code was not updated to remove the
use of getObj.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/153#comment:2>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
