[fusion-trac] #158: MG Map Background Color Ignored
Fusion trac_fusion at osgeo.org
Thu Nov 6 15:56:29 EST 2008
 Reporter:  chrisclaydon        |         Owner:  madair
     Type:  defect              |        Status:  new
 Priority:  P2                  |     Milestone:  2.0
Component:  Widgets             |       Version:  SVN
 Severity:  Major               |    Resolution:
 Keywords:                      |   External_id:  1154050
    State:  Analysis Requested  |       Browser:  All
       Os:  All                 |
Comment (by jbirch):
 Is this because Fusion is now using overlay images instead of map images?
 In the case of only a single map, I wonder if you could extract the map
 background colour from the map definition, and set the colour of the map
 div based on that.
 When you get into supporting multiple maps, then some kind of logic will
 be required to determine which background colour to use.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/158#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
