[fusion-trac] #161: MG layers using filter containing double quotes cause legend error on startup
Fusion trac_fusion at osgeo.org
Thu Nov 6 17:50:56 EST 2008
startup
   Reporter:  chrisclaydon  |       Owner:  madair
       Type:  defect        |      Status:  new
   Priority:  P2            |   Milestone:  2.0
  Component:  Widgets       |     Version:  SVN
   Severity:  Major         |    Keywords:
External_id:  1152239       |       State:  Analysis Requested
    Browser:  All           |          Os:  All
 Load the attached MG package and view the Fusion layout. An error occurs
 on startup because the quotes in the filter for the layer's first theme
 get escaped twice.
 i.e. " is replaced with \\"
 This causes an error when trying to parse the scale ranges. The error is
 displayed in a dialog, and the legend fails to render.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/161>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
