[fusion-trac] #161: MG layers using filter containing double
quotes cause legend error on startup
Fusion
trac_fusion at osgeo.org
Fri Nov 7 15:57:30 EST 2008
#161: MG layers using filter containing double quotes cause legend error on
startup
Reporter: chrisclaydon | Owner: pagameba
Type: defect | Status: closed
Priority: P2 | Milestone: 2.0
Component: Widgets | Version: SVN
Severity: Major | Resolution: fixed
Keywords: | External_id: 1152239
State: Analysing | Browser: All
Os: All |
Changes (by pagameba):
* status: assigned => closed
* resolution: => fixed
Comment:
(In [1653]) Fixes #161. addslashes was necessary when we were echo
outputting the JSON response but var2json now escapes values so adding
slashes for text is no longer required and in fact wrong because var2json
escapes the slashes (causing this bug).
Ticket URL: <http://trac.osgeo.org/fusion/ticket/161#comment:2>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
