[fusion-trac] #155: Layout fails to re-load when browser refresh button is pushed (in IE7 with default settings)
Fusion trac_fusion at osgeo.org
Fri Nov 7 16:40:53 EST 2008
default settings)
 Reporter:  chrisclaydon        |         Owner:  madair
     Type:  defect              |        Status:  assigned
 Priority:  P1                  |     Milestone:  2.0
Component:  Core                |       Version:  SVN
 Severity:  Major               |    Resolution:
 Keywords:                      |   External_id:  1152238
    State:  Analysis Requested  |       Browser:  All
       Os:  All                 |
Comment (by madair):
 (In [1655]) re #155: use setTimeout to call getAppDef so that
 ApplicationDefinition.parse will return before
 Fusion.setLaodState(LOAD_WIDGETS) gets called (otherwise
 Fusion.ApplicationDefinition is null).  When the browser is set to read
 files from cache, the AppDef is retrieved from cache and the sequence of
 callbacks is executed too quickly
Ticket URL: <http://trac.osgeo.org/fusion/ticket/155#comment:5>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
