[fusion-trac] #166: Restructure MapGuide-specific widget code
Fusion trac_fusion at osgeo.org
Mon Nov 10 20:54:20 EST 2008
   Reporter:  pagameba  |       Owner:  madair
       Type:  task      |      Status:  new
   Priority:  P1        |   Milestone:  2.0
  Component:  Widgets   |     Version:  1.1.0
   Severity:  Major     |    Keywords:
External_id:            |       State:  New
    Browser:  All       |          Os:  All
 The current Print widget and probably some other widgets (Select Within
 comes to mind) only support MapGuide since we brought over code from the
 AJAX viewer, but the code has been placed in subdirectories under the
 widgets folder.  This needs to be reorganized to put the code into a
 MapGuide directory (within each widgets' supporting folder) so that we can
 properly support MapServer when the time comes to implement it.
 I would like to see the code reorganized into an architecture/language
 structure (for example):
 widgets/Print/MapGuide/php/
 The client-side code will have to be updated to get the current
 architecture and script language from the Map instance.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/166>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
