[fusion-trac] #57: Zoom Window with World-Miller Coord Sys
Incorrect
Fusion
trac_fusion at osgeo.org
Tue Nov 11 19:46:43 EST 2008
#57: Zoom Window with World-Miller Coord Sys Incorrect
Reporter: amorsell | Owner: madair
Type: defect | Status: assigned
Priority: P1 | Milestone: 2.0
Component: Core | Version: 1.0.4
Severity: Major | Resolution:
Keywords: | External_id:
State: Analysis Requested | Browser: All
Os: All |
Comment (by amorsell):
This is data from a client and configured as they had it setup in their
old site. You're right, the map coordinate system does not look correct.
But, changing it to LL83 and the map and overview map still exhibit the
same problems. It seems that the zoom functionality would be independent
of the coordinate system assigned and would work consistently with a map
relative to itself. Could it just be some zoom rectangle bounding box
coordinate rounding issues since the scale is very small in this case?
Ticket URL: <http://trac.osgeo.org/fusion/ticket/57#comment:3>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
