[fusion-trac] #155: Layout fails to re-load when browser refresh button is pushed (in IE7 with default settings)
Fusion trac_fusion at osgeo.org
Wed Nov 12 12:48:49 EST 2008
default settings)
 Reporter:  chrisclaydon        |         Owner:  madair
     Type:  defect              |        Status:  reopened
 Priority:  P1                  |     Milestone:  2.0
Component:  Core                |       Version:  SVN
 Severity:  Major               |    Resolution:
 Keywords:                      |   External_id:  1152238
    State:  Analysis Requested  |       Browser:  All
       Os:  All                 |
Changes (by chrisclaydon):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 This now works in IE unless the SESSION parameter is used for
 authentication. e.g.
 http://localhost:8008/mapguide2010/fusion/templates/mapguide/slate/index.html?ApplicationDefinition=Library%3a%2f%2fSheboygan.ApplicationDefinition&SESSION=
 b82771f4-9300-102b-8000-001e37d08476_en_7F0000010AF20AF10AF0
 In this case, it still fails to refresh.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/155#comment:7>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
