[fusion-trac] #170: clean target is invoked after prepare target
when running default ant build task
Fusion
trac_fusion at osgeo.org
Fri Nov 14 21:41:48 EST 2008
#170: clean target is invoked after prepare target when running default ant build
task
Reporter: jng | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: 2.0
Component: Core | Version: 1.1.0
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
Run ant in the fusion directory with no optional parameters.
It will say BUILD FAILED at build.xml:205 ${fusion directory}\build\text
not found.
If you look at the output, the clean target is executed *after* the
prepare target has been executed, the net result is that nothing has been
copied.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/170>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
