[fusion-trac] #171: Widget info should use image sprites as default widget images
Fusion trac_fusion at osgeo.org
Mon Nov 17 16:25:41 EST 2008
   Reporter:  chrisclaydon  |       Owner:  chrisclaydon
       Type:  defect        |      Status:  new
   Priority:  P3            |   Milestone:  2.0
  Component:  MapGuide      |     Version:  SVN
   Severity:  Major         |    Keywords:
External_id:  1161182       |       State:  Analysing
    Browser:  All           |          Os:  All
 Fusion now supports image sprites, allowing for a vast reduction in the
 size and number of downloads required to produce the icons for all the
 buttons and menu items in a Fusion layout.
 The widget info files will be updated, so that new widget instances
 created by an application that utilizes the widget info will automatically
 make use of image sprites.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/171>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
