[fusion-trac] #171: Widget info should use image sprites as default widget images
Fusion trac_fusion at osgeo.org
Mon Nov 17 16:33:25 EST 2008
 Reporter:  chrisclaydon  |         Owner:  chrisclaydon
     Type:  defect        |        Status:  closed
 Priority:  P3            |     Milestone:  2.0
Component:  MapGuide      |       Version:  SVN
 Severity:  Major         |    Resolution:  fixed
 Keywords:                |   External_id:  1161182
    State:  Analysing     |       Browser:  All
       Os:  All           |
Changes (by chrisclaydon):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 (In [1669]) Fixes #171 - Updated widget info files to use CSS image
 sprites by default for widget icons.
 CSS image sprites allow multiple icons to be obtained from a single image
 strip image. This greatly reduces the number of downloads required when a
 Fusion layout is loaded, allowing for a quicker start-up.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/171#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
