[fusion-trac] #176: Legend widget misbehaves when you set maxscaledenom to a layer that is outside the web min / maxscale
Fusion trac_fusion at osgeo.org
Wed Nov 19 14:21:46 EST 2008
   Reporter:  pdeschamps  |       Owner:  madair
       Type:  defect      |      Status:  new
   Priority:  P2          |   Milestone:  2.0
  Component:  Widgets     |     Version:  1.1.0
   Severity:  Minor       |    Keywords:
External_id:              |       State:  New
    Browser:  All         |          Os:  All
 Using fusion 1.1 rev 1581 also reproducible in trunk rev 1675
 Using the "/templates/mapserver/standard/" application
 Using gmap.
 Steps to reproduce:
 set your WEB section to this:
 WEB
   MINSCALE 2000000
   MAXSCALE 50000000
 # On Windows systems, /tmp and /tmp/ms_tmp/ should be created at the root
 # of the drive where the .MAP file resides.
   IMAGEPATH "/home/pdeschamps/fgs/tmp/ms_tmp/"
   IMAGEURL "/home/pdeschamps/fgs/tmp/ms_tmp/"
 END
 add the maxscaledenom to the rail layer
 LAYER
   NAME rail
   MAXSCALEDENOM 1000000
   METADATA
     "DESCRIPTION" "Railroads"
   END
   TYPE LINE
   STATUS ON
   DATA rail
   CLASS
     NAME "Railroads"
     STYLE
        SIZE 1
        SYMBOL "circle"
       COLOR 168 0 184
     END
   END
 END # Layer
 When you set a layer to have a maxscaledenom of 1,000,000 when your
 web->maxscale is set to 2,000,000 the legend misbehaves.
 Zoom in the the 1:200,000 and notice that the legend has toggled all the
 layers as inactive.
 Understandable issue as the user should not specify a maxscale or minscale
 that is outside of the web's min / maxscale.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/176>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
