[fusion-trac] #178: Map reloads multiple times
Fusion trac_fusion at osgeo.org
Wed Nov 26 12:20:00 EST 2008
 Reporter:  chrisclaydon        |         Owner:  madair
     Type:  defect              |        Status:  assigned
 Priority:  P2                  |     Milestone:  2.0
Component:  Widgets             |       Version:  SVN
 Severity:  Major               |    Resolution:
 Keywords:                      |   External_id:  1163882
    State:  Analysis Requested  |       Browser:  All
       Os:  All                 |
Changes (by chrisclaydon):
  * priority:  P1 => P2
Comment:
 This is a weird bug. It only shows up when I have the !ForecastFox
 extension (a weather-reporting add-on) enabled in Firefox 3. Even then, if
 I set the add-on to display in the status bar, everything is fine. But if
 I set it to display in any location above the main window, I get the
 reloading problem consistently.
 I'm going to downgrade the priority setting of this ticket, though it
 would still be great to fix it, if possible.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/178#comment:4>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
