[fusion-trac] #173: Stack overflow errors in IE related to
context menus
Fusion
trac_fusion at osgeo.org
Thu Nov 27 09:59:31 EST 2008
#173: Stack overflow errors in IE related to context menus
Reporter: chrisclaydon | Owner: pagameba
Type: defect | Status: assigned
Priority: P1 | Milestone: 2.0
Component: Core | Version: SVN
Severity: Major | Resolution:
Keywords: | External_id: 1161259
State: Analysing | Browser: IE7
Os: All |
Comment (by pagameba):
The culprit is the eventInMenu method of menus, it has a recursive check
to see if an event happened inside the menu before deciding if the mouse
event should close the menu. The stack overflow seems to be triggered by
a deeply nested call stack in IE, and recursion is often at fault.
I'm figuring out if we can refactor the code to remove the recursion.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/173#comment:3>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
