[fusion-trac] #67: Determine Fusion's handling of relative
paths for MapFiles
Fusion
trac_fusion at osgeo.org
Thu Nov 27 10:11:54 EST 2008
#67: Determine Fusion's handling of relative paths for MapFiles
Reporter: jfournier | Owner: pdeschamps
Type: enhancement | Status: closed
Priority: P1 | Milestone: 2.0
Component: MapServer | Version: 1.0.6
Severity: Critical | Resolution: fixed
Keywords: | External_id:
State: New | Browser: All
Os: All |
Changes (by pdeschamps):
* status: assigned => closed
* resolution: => fixed
Comment:
added mapfileroot to config.json.
With a file_exists call LoadMap.php now looks first for a path relative
from the fusion root by default. If mapfileroot is specified in
config.json it will try that specified path with a file_exists call as
well, If both of these fail then it uses an absolute path. (for backwards
compatibility)
Ticket URL: <http://trac.osgeo.org/fusion/ticket/67#comment:3>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
