[fusion-trac] #135: Drop-down mouse interaction being interfered
with by map in Safari and sometimes in Fusion
Fusion
trac_fusion at osgeo.org
Thu Oct 2 14:12:13 EDT 2008
#135: Drop-down mouse interaction being interfered with by map in Safari and
sometimes in Fusion
Reporter: jbirch | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: 1.1
Component: Widgets | Version: SVN
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
On my map, I have a toolbar at the top that has a three-item flyout menu.
In Internet explorer, this flyout works fine; all of the items are always
available to click on when the menu is active.
In Safari (Windows), the map seems to steal the mouseover when the flyout
is active, not allowing me to click on the bottom toolbar item in the
flyout, which overlaps the map.
In FireFox 3 (Windows), the flyout usually works, but if I first radius-
select some items on the map in the area where the flyout covers, and then
try to use the flyout it exhibits the same behaviour as Safari.
I'm running from the 1.1 branch.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/135>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
