[fusion-trac] #143: Incorrect scale displayed for maps using units other than meters
Fusion trac_fusion at osgeo.org
Thu Oct 30 13:33:43 EDT 2008
   Reporter:  chrisclaydon  |       Owner:  madair
       Type:  defect        |      Status:  new
   Priority:  P2            |   Milestone:  2.0
  Component:  Widgets       |     Version:  SVN
   Severity:  Major         |    Keywords:
External_id:  1085634       |       State:  Analysis Requested
    Browser:  All           |          Os:  All
 When a !MapGuide map is displayed using Fusion, the initial map view is
 incorrect for maps that do not use a coordinate system with meters as the
 units.
 The difference between the desired and actual scale seems to be consistent
 with the difference in size of the actual units from meters.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/143>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
