[fusion-trac] #42: config.json should be renamed to config_dist.json
Fusion trac_fusion at osgeo.org
Fri Oct 31 13:31:49 EDT 2008
 Reporter:  wbronsema    |         Owner:  madair
     Type:  enhancement  |        Status:  closed
 Priority:  P2           |     Milestone:  1.1
Component:  Core         |       Version:  1.0.4
 Severity:  Trivial      |    Resolution:  fixed
 Keywords:               |   External_id:
    State:  Approved     |       Browser:  All
       Os:  All          |
Comment (by madair):
 (In [1629]) re #42: also rename config_dist.json to config.json as part of
 the build process
Ticket URL: <http://trac.osgeo.org/fusion/ticket/42#comment:10>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
