[fusion-trac] #276: MapGuide selection fails to draw
Fusion
trac_fusion at osgeo.org
Tue Aug 11 16:43:33 EDT 2009
Reporter: jbirch | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: 2.0
Component: Widgets | Version: SVN
Severity: Major | Resolution:
Keywords: | External_id:
State: New | Browser: All
Os: All |
Comment (by greenmapsanmiguel):
I tested with the potential solution reported by Andreas Morf. This
solution works for me *if* I reverse the comments so that the command
passes 'true':
this.queryLayer = this.createOLLayer("query layer", true, 5);
// this.queryLayer = this.createOLLayer("query layer", false, 5);
this.queryLayer.isBaseLayer = false;
My map does not use tiling. Selections are now correctly highlighted and
the pink tile boxes no longer appear.
Looks like Andreas is on the right track but that some conditional code
may be needed so it works for all maps.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/276#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
