[fusion-trac] #281: Map does not display when mixing base group (tiled layers) and normal layers
Fusion trac_fusion at osgeo.org
Fri Aug 21 14:05:46 EDT 2009
layers
   Reporter:  greenmapsanmiguel  |       Owner:  madair
       Type:  defect             |      Status:  new
   Priority:  P2                 |   Milestone:  Future
  Component:  MapGuide           |     Version:  1.1.1
   Severity:  Major              |    Keywords:
External_id:                     |       State:  New
    Browser:  All                |          Os:  All
 Maps with both a base group (tiled layers) and normal layers do not
 display correctly.  The map appears to funcion even though nothing is
 being displayed.  With SingleTile set to false:
 nothing is displayed in the map pane(just background color)
 nothing is displayed in the overview pane, but red rectangle is placed
 correctly
 legend displays correctly but selecting a layer doesn't cause it to
 display
 select and zoom work for both base and regular layers, including correctly
 displaying the highlighted feature
Ticket URL: <http://trac.osgeo.org/fusion/ticket/281>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
