[fusion-trac] #141: Legend widget is not updating correctly
Fusion trac_fusion at osgeo.org
Mon Dec 7 10:10:09 EST 2009
 Reporter:  CivilEng  |         Owner:  madair
     Type:  defect    |        Status:  assigned
 Priority:  P2        |     Milestone:  2.0
Component:  Widgets   |       Version:  1.0.6
 Severity:  Critical  |    Resolution:
 Keywords:            |   External_id:
    State:  New       |       Browser:  All
       Os:  Windows   |
Comment (by civileng):
 Replying to [comment:3 madair]:The trunk SVN version is working perfectly.
 Also I have tested with the fusion version that come with the mapguide
 2.1.0.4283-final. In this case this issue still is present.
 > this is committed to trunk so if you can test the trunk from SVN that
 woud be helpful
Ticket URL: <http://trac.osgeo.org/fusion/ticket/141#comment:4>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
