[fusion-trac] #333: Bing: Map with Bing maps doesn't refresh when browser maximize
Fusion trac_fusion at osgeo.org
Wed Dec 9 15:36:26 EST 2009
 Reporter:  jennyhe  |         Owner:  madair
     Type:  defect   |        Status:  new
 Priority:  P2       |     Milestone:  Future
Component:  Widgets  |       Version:  1.1.1
 Severity:  Major    |    Resolution:
 Keywords:           |   External_id:  1279971
    State:  New      |       Browser:  All
       Os:  All      |
Comment (by chrisclaydon):
 This problem occurs because the class OpenLayers.Layer.VirtualEarth in the
 version of OpenLayers.js used by Fusion does not contain an override of
 the base class onMapResize() method (which does nothing).
 The version of this class in the trunk stream of OpenLayers does implement
 the method as follows:
      * Method: onMapResize
     onMapResize: function() {
         this.mapObject.Resize(this.map.size.w, this.map.size.h);
 Pasting this into the OpenLayers.js used by Fusion resolves this defect. I
 will attach a patch for this.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/333#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
