[fusion-trac] #355: Redline listen to the right click
Fusion trac_fusion at osgeo.org
Wed Dec 16 22:10:31 EST 2009
   Reporter:  hubu     |       Owner:  hubu
       Type:  defect   |      Status:  new
   Priority:  P2       |   Milestone:  Future
  Component:  Widgets  |     Version:  1.1.1
   Severity:  Major    |    Keywords:
External_id:  1267031  |       State:  New
    Browser:  All      |          Os:  All
 1. Open a Flexible weblayout in the browser from MapGuide.
 2. Activate the "Redline" widget
 3. Select "Point" as the Draw option
 4. Right click on the map.
 result:
 The contextual menu is activated and the user still can digitize on the
 map.
 Expected:
 The Redline widget should listen to the right-click.
 Comments:
 The "Select Polygon" and "Measure" have the same problem
Ticket URL: <http://trac.osgeo.org/fusion/ticket/355>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
