[fusion-trac] #354: Zoom Rectangle windows touching Overview Map widget will fail
Fusion trac_fusion at osgeo.org
Mon Dec 21 03:07:43 EST 2009
 Reporter:  liuar     |         Owner:  madair
     Type:  defect    |        Status:  closed
 Priority:  P2        |     Milestone:  Future
Component:  Widgets   |       Version:  1.1.1
 Severity:  Major     |    Resolution:  wontfix
 Keywords:            |   External_id:  1288398.01
    State:  Deferred  |       Browser:  All
       Os:  All       |
Changes (by liuar):
  * status:  new => closed
  * state:  New => Deferred
  * resolution:  => wontfix
Comment:
 It is as designed, because the box (rectangle) is a handler for Map
 widget, if the cursor moved out of current map, moved to the toolbar for
 example, the box will disappeared. For the same reason, if the cursor
 moved to the  overview map widget, the box should be removed.
 There's a workaround-  Moving the overview map widget out of current map
 widget, then it will not interfere the box dragging.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/354#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
