[fusion-trac] #192: Legend becomes garbled when expanded/collapsed
Fusion
trac_fusion at osgeo.org
Wed Feb 4 18:32:29 EST 2009
Reporter: chrisclaydon | Owner: madair
Type: defect | Status: reopened
Priority: P1 | Milestone: 2.0
Component: Widgets | Version: SVN
Severity: Major | Resolution:
Keywords: | External_id: 1176823
State: Analysis Requested | Browser: IE7
Os: All |
Changes (by chrisclaydon):
* status: closed => reopened
* resolution: fixed =>
Comment:
Even with the change made in submission 1774, when I first open a layout
based on the Sheboygan sample map, the Transportation layer appears in the
wrong place (see attached screenshot). Repeated zooming in and out can
also still cause the legend to become garbled. So it doesn't appear to fix
the problem.
A dotted line up to the top of the legend, a small piece of the label from
the "hidden" root folder, and sometimes the highlighting from the root
node itself are also visible...
Ticket URL: <http://trac.osgeo.org/fusion/ticket/192#comment:6>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
