[fusion-trac] #209: Measure Widget broken in IE7 when invoked from
menu rather than toolbar
Fusion
trac_fusion at osgeo.org
Thu Feb 5 12:15:08 EST 2009
#209: Measure Widget broken in IE7 when invoked from menu rather than toolbar
Reporter: chrisclaydon | Owner: madair
Type: defect | Status: new
Priority: P1 | Milestone: 2.0
Component: Widgets | Version: SVN
Severity: Major | Keywords:
External_id: 1166032 | State: Analysis Requested
Browser: All | Os: All
In the fusion-mg21 branch (probably in trunk too), when the Measure widget
is invoked from the task pane task list menu, or from the map's right-
click menu, it fails to work properly in IE7. The lines and segment labels
do not get drawn.
It works better in Firefox, though it fails to pick up the units from the
map correctly, so they show up as "unk" unless explicitly set using the
Options dropdown.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/209>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
