[fusion-trac] #57: Zoom Window with World-Miller Coord Sys
Incorrect
Fusion
trac_fusion at osgeo.org
Tue Jan 20 13:23:35 EST 2009
#57: Zoom Window with World-Miller Coord Sys Incorrect
Reporter: amorsell | Owner: madair
Type: defect | Status: closed
Priority: P1 | Milestone: 2.0
Component: Core | Version: 1.0.4
Severity: Major | Resolution: invalid
Keywords: | External_id:
State: Analysis Requested | Browser: All
Os: All |
Changes (by madair):
* status: assigned => closed
* resolution: => invalid
Comment:
I suspect that the very small scale is the issue here (extent interpreted
as meters gives a total extent of about 5m x 5m). Also, the large values
for the OverviewMap min and max ratio parameters mean that the overview
map is zoomed out much too far so rounding errors will throw off the
rectangle.
Closing this for now. If the problem persists with correct units for the
map definition and better min/max ration parameters please re-open the
issue.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/57#comment:4>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
