[fusion-trac] #207: Search widget is broken
Fusion trac_fusion at osgeo.org
Fri Jan 30 14:12:25 EST 2009
   Reporter:  chrisclaydon  |       Owner:  madair
       Type:  defect        |      Status:  new
   Priority:  P1            |   Milestone:  2.0
  Component:  Widgets       |     Version:  1.1.0
   Severity:  Major         |    Keywords:
External_id:  1142170.01    |       State:  Approved
    Browser:  All           |          Os:  All
 If a Search widget is added to a Fusion layout as a toolbar button, the
 button does not show up on the toolbar.
 This is because the widget fails to declare itself as a UI object.
 Once that is fixed, the button shows up, but when it is clicked none of
 the widget settings are picked up by the php script that gets invoked.
 This happens because the script tries to look up the widget based on its
 ID, but it has no ID configured.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/207>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
