[fusion-trac] #236: Search.php errors
Fusion trac_fusion at osgeo.org
Tue Jul 14 15:34:31 EDT 2009
 Reporter:  amorsell  |         Owner:  waltweltonlair
     Type:  defect    |        Status:  assigned
 Priority:  P2        |     Milestone:  2.0
Component:  Widgets   |       Version:  1.1.1
 Severity:  Major     |    Resolution:
 Keywords:            |   External_id:  1015380
    State:  New       |       Browser:  All
       Os:  All       |
Changes (by waltweltonlair):
  * status:  new => assigned
Comment:
 The attached patch addresses both #236 and #268.  It's a port of the fixes
 for the following MapGuide tickets:
  * MG ticket 382 (Implement RFC 43 - Support Search and Selection on
 Double Identity Properties)
   * [https://trac.osgeo.org/mapguide/changeset/2686]
    * add support for Int64 and Double identity properties
   * [https://trac.osgeo.org/mapguide/changeset/3009]
    * fix additional issues with Single and !DateTime identity properties
    * add support for feature classes with multiple identity properties
  * MG ticket 693 (PHP and ASP AJAX viewer fixes needed for simple search
 on NULL values)
   * [https://trac.osgeo.org/mapguide/changeset/3317]
    * add support for NULL values
  * MG ticket 1028 (Fix some PHP script typos)
   * [https://trac.osgeo.org/mapguide/changeset/3999]
Ticket URL: <http://trac.osgeo.org/fusion/ticket/236#comment:4>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
