[fusion-trac] #266: Maptips Should Only Show for Visible Layers
Fusion trac_fusion at osgeo.org
Tue Jun 30 13:39:32 EDT 2009
   Reporter:  tnolte   |       Owner:  madair
       Type:  defect   |      Status:  new
   Priority:  P2       |   Milestone:  Future
  Component:  Widgets  |     Version:  1.1.1
   Severity:  Major    |    Keywords:  maptips
External_id:           |       State:  New
    Browser:  All      |          Os:  All
 If a layer is not visible, showing within the current scale, then Maptips
 shouldn't show. You could possibly add parameters to each <Maptip> section
 in the ApplicationDefinition that would control independently the min/max
 scale. That would only be necessary if someone needed Maptips to show
 independently from the layers scale settings. I'm not sure how this
 applies to MapGuide. I'm only aware of this needed for MapServer as I have
 not used MapGuide.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/266>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
