[fusion-trac] #266: Maptips Should Only Show for Visible Layers
Fusion trac_fusion at osgeo.org
Tue Jun 30 15:42:53 EDT 2009
 Reporter:  tnolte   |         Owner:  madair
     Type:  defect   |        Status:  new
 Priority:  P2       |     Milestone:  Future
Component:  Widgets  |       Version:  2.0 - beta
 Severity:  Major    |    Resolution:
 Keywords:  maptips  |   External_id:
    State:  New      |       Browser:  All
       Os:  All      |
Comment (by tnolte):
 So after further investigation it would seem that the MapServer
 Maptips.php script is in fact creating a completely new map object and it
 is created with the default mapfile extents. This means that with even
 being zoomed in the full original map extents are used. Looks like the
 Maptips script should be getting the current map extents or scale. Also I
 found that the JSON data that is being reported for MapServer layers that
 aren't visible at the current scale is wrong. It's reporting the the layer
 is "visible" which is not correct. Looks like I might need to open another
 ticket for that.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/266#comment:2>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
