[fusion-trac] #230: Fusion is incorrectly assuming that MapGuide will be installed in "webserverextensions"
Fusion trac_fusion at osgeo.org
Tue Mar 31 08:29:48 EDT 2009
 Reporter:  jbirch    |         Owner:  pagameba
     Type:  defect    |        Status:  assigned
 Priority:  P2        |     Milestone:  2.0
Component:  MapGuide  |       Version:  2.0 - beta
 Severity:  Blocker   |    Resolution:
 Keywords:            |   External_id:
    State:  New       |       Browser:  All
       Os:  All       |
Changes (by pagameba):
  * status:  new => assigned
  * owner:  madair => pagameba
Comment:
 it looks like the pertinent code is on line 39/40 of
 layers/MapGuide/php/Common.php
 $defaultInstallDir = dirname(__FILE__)."/../../../../../../";
 $defaultExtensionDir = realpath($defaultInstallDir .
 "webserverextensions/www/");
 looks like it should be:
 $defaultExtensionDir = dirname(__FILE__)."/../../../../";
 $defaultInstallDir = realpath($defaultExtensionDir)."/../../";
 and then all would be good.  Note that I don't think $defaultInstallDir is
 used at all.  $defaultExtensionDir is only used to find webconfig.ini.  If
 someone could test this change using the attached patch, I can commit ...
Ticket URL: <http://trac.osgeo.org/fusion/ticket/230#comment:2>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
