[fusion-trac] #287: Fail to narrow Task pane when drag the
Vertical Line
Fusion
trac_fusion at osgeo.org
Mon Nov 2 15:08:05 EST 2009
#287: Fail to narrow Task pane when drag the Vertical Line
Reporter: jennyhe | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: Future
Component: Widgets | Version: 1.1.1
Severity: Major | Resolution:
Keywords: | External_id: 1254170
State: New | Browser: All
Os: All |
Comment (by chrisclaydon):
This behavior only seems to happen for the task pane. Dragging over the
legend or selection panel works correctly. Also, if no page is loaded in
the task pane, it also works. So it appears that the iFrame loaded in the
task pane is grabbing the drag events, and they are not making it back to
Fusion. I talked to Paul Spencer about this, and it is his opinion that
this should be addressed in the Jx library code.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/287#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
